Author Topic: Does EA generate code for ports?  (Read 4307 times)
mse
« on: March 01, 2019, 06:35:52 pm »
I inserted a class in a diagram and created a port and attached it to the class. I then added a required Interface to that port. All elements named Class3, Port2, and Interface1 have the language set to C++. In the end however, all I get is this:
class Class3
public:
Class3();
virtual ~Class3();
class Interface1
public:
Interface1() {
virtual ~Interface1() {
Code for the port Port2 is not generated. I know that in other tools, a port will translate to an embedded class. EA architect seems to not support port code generation. Am I missing something else, say perhaps another setting?
Re: Does EA generate code for ports?
« Reply #1 on: March 02, 2019, 05:45:44 am »
In EA nested classes get translated to nested classes.
I don't think ports are used at all in code generation.
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
« Reply #2 on: March 07, 2019, 09:01:24 am »
I think the same, so, what do you expect the ports to be transformed into?
shiba28
« Reply #3 on: May 02, 2019, 01:44:12 am »
I believe that EA's code template framework didn't directly support generation of ports and parts. However, this functionality was intended to be added to the code template framework. someone from the support team can confirm that.
dafont192.168.1.1filehippo
« Last Edit: May 03, 2019, 04:55:48 am by shiba28 »
