Author Topic: <SOLVED> Document Generation StyleSheet Heading Numbering Style  (Read 13872 times)
berch33
Hi everyone!
Short: what I need: a stylesheet where there is more space between heading (3) numbering and heading text itself, eg.
currently:  1.1.1My Heading
expected: 1.1.1   My Heading
Long: I know how to edit the heading 3 (font), won’t help. I know how to edit the numbering font (Edit  List & Overrides  Edit list level  Number Font), won’t help.
Maybe it is a Tab-Stop. I know that you can show rulers (View  show…), but when I klick Edit  Edit Style, moving the little grey triangles will move the whole ident, not the tab. And Tab (black edge) is not shown…
Help appreciated, thanks in advance!
« Last Edit: March 06, 2019, 07:48:21 pm by berch33 »
Re: Document Generation StyleSheet Heading Numbering Style
« Reply #1 on: March 05, 2019, 03:04:59 am »
I just experimented a bit, and the bottom grey triangle controls the start of the heading text whereas the top triangle controls the start of the heading number.
So you should drag the bottom triangle a bit to the right to get the result you are after.
Sunshine
  • Its the results that count
« Reply #2 on: March 05, 2019, 04:26:15 pm »
You can always export the style sheet or template and set it up using MS Word then import if you have difficulties with the Sparx EA Word editor
Happy to help
berch33
« Reply #3 on: March 06, 2019, 07:47:14 pm »
This is the working answer! Thank you, I was able to get it to work!
