Author Topic: Extend Image Library  (Read 3898 times)
milan.petrak
« on: March 06, 2019, 11:01:41 pm »
Some time is good to have more vector images form another GNU projects
OSA
https://www.opensecurityarchitecture.org/cms/library/icon-library
XML to import as a reference data
https://drive.google.com/open?id=1Rv-roVrXgC5-XMVqmf6ex-goLBouTOKB
VRT
https://github.com/klump/vrt-sheet-for-dia/tree/new-svg
https://drive.google.com/open?id=1aCBVzYMX2DBw365BUeKDPiThlJJv0Shv
If you will need create another libraries
You will need inkscape as a svg to emf convertor
https://inkscape.org/
script prepare.bat
for /R %%f in (*.svg) do (
"C:\Program Files\Inkscape\inkscape" --file %%~NXf --export-emf %%~Nf.emf
type header.xml > ImageLibrary.xml
del data.b64
del tmp.b64
setlocal enabledelayedexpansion
for /R %%f in (*.emf) do (
set /A Counter+=1
echo ^<DataRow^> >> ImageLibrary.xml
echo ^<Column name=^"ImageID^" value=^"!Counter!^"^/^> >> ImageLibrary.xml
echo ^<Column name=^"Name^" value=^"%%~Nf^"^/^> >> ImageLibrary.xml
echo ^<Column name=^"Type^" value=^"Metafile^"^/^> >> ImageLibrary.xml
echo ^<Column name=^"Image^" xmlns:dt=^"urn:schemas-microsoft-com:datatypes^" dt:dt=^"bin.base64^"^> >> ImageLibrary.xml
certutil -encode %%f tmp.b64 && findstr /v /c:- tmp.b64 > data.b64
type data.b64 >> ImageLibrary.xml
echo ^<^/Column^> >> ImageLibrary.xml
echo ^<^/DataRow^> >> ImageLibrary.xml
del data.b64
del tmp.b64
endlocal
type footer.xml >> ImageLibrary.xml
header.xml file
<?xml version="1.0" encoding="windows-1252"?>
<RefData version="1.0" exporter="EA.25">
<DataSet name="VRT Images" table="t_image" filter="Name='#Name#'" stoplist=";ImageID;">
footer.xml file
</DataSet>
</RefData>
Sunshine
  • Its the results that count
Re: Extend Image Library
« Reply #1 on: March 07, 2019, 06:27:04 am »
Thanks for sharing
Happy to help
