Author Topic: Connector to Package leads to EA Crash  (Read 9552 times)
A.K.
« on: June 14, 2012, 05:45:15 pm »
Hello
I have to create some connectors from packages to elements and vice versa. However, when i do  so, the EA crashes with an SEHException.
None of the following approaches have worked so far:
1)
Create Element A
Create Package B
Create Connector C by ElementA.Connectors.Add
Link Connector to the Element of the Package (PackageB.Element)
2)
Create Element A
Create Package B
Create Connector C by PackageB.Connectors.Add
Link Connector to the Element A
3)
Create Element A
Create Package B
Create Connector C by PackageB.Element.Connectors.Add
Different connector types such as "Package" (this type of connector is created when adding the connectors in EA manually) had no influence on the situation.
Any help is very appreciated!
Thanks!
Greetings,
Alex
Re: Connector to Package leads to EA Crash
« Reply #1 on: June 14, 2012, 07:36:14 pm »
Alex,
Have you tried connecting two existing packages/elements?
If that works it might be enough to reload the objects from the repository.
A.K.
« Reply #2 on: June 14, 2012, 09:11:35 pm »
As always I found it out just in the moment when I posted the question
the type must be "Dependency"
