Author Topic: Reporting Traceability  (Read 7393 times)
Graham_Moir
« on: March 07, 2019, 10:49:09 pm »
This topic has come up before - how do you get the very useful information reported via the traceability window in to a report?   I just did a search and there have been a few threads on this over the years, usually voicing frustration that it's not supported out of the box with a standard template.
Well I've been away, and was just wondering whether there has been any progress with this?  Or does someone have an example template to achieve it?
Re: Reporting Traceability
« Reply #1 on: March 07, 2019, 11:59:58 pm »
We do it using an SQL fragment.
Graham_Moir
« Reply #2 on: March 08, 2019, 12:26:21 am »
Is it possible to share that Geert?
« Reply #3 on: March 08, 2019, 07:16:11 pm »
We have a few of those traceability fragments, but they are all pretty specific
Here's an example of a fragment that shows the requirements referenced by the use case using a «trace» link
select uc.Name as SourceName, 'Use Case' as SourceType, 'trace' as ConnectorType,
ro.Name as TargetName,
'Application Requirement' as TargetType
from t_object uc
inner join t_package p on p.Package_ID = uc.Package_ID
inner join t_connector c on c.Start_Object_ID = uc.Object_ID
                                         and c.Connector_Type = 'Abstraction'
                                         and c.Stereotype = 'trace'
inner join t_object ro on ro.Object_ID = c.End_Object_ID
and ro.Object_Type = 'Requirement'
where
uc.Object_Type = 'UseCase'
and uc.Object_ID = #OBJECTID#
union
select 'N/A' as SourceName, 'N/A' as SourceType, 'N/A' as ConnectorType, 'N/A' as TargetName, 'N/A' as TargetType
where not exists
select uc.Object_ID from t_object uc
where
order by SourceName, TargetType, TargetName
the results go into a table on the template:
Application Requirements
custom >
Source type   Source name   Relationship   Target type   Target name
{SourceType}   {SourceName}   {ConnectorType}   {TargetType}   {TargetName}
< custom
Graham_Moir
« Reply #4 on: March 09, 2019, 01:53:50 am »
Thank you Geert !
