Author Topic: Connector Autocolor legends don't apply Line Width with shapescript  (Read 3572 times)
If you try to set up an autocolor connector Legend you'll likely encounter some difficulties (if you have a shape script).
It turns out that if your shapescript DOESN'T have a shape main {}, then the line width aspect of the legend will be applied.  As soon as you create the simplest shape main {} the connector no longer responds to the linewidth value.
shape main
noshadow = true;
moveto(0,0);
lineto(100,0);
The line colour is correctly applied in all cases.
This was tested with the Connector.Stereotype filter, but previous testing shows the problem to be universal.
Please rectify.
Reported,
