Author Topic: 1 or many metaclasses  (Read 3250 times)
Modesto Vega
« on: March 12, 2019, 08:20:25 pm »
I have noticed that when creating a profile I can drop a metaclass and connect to it as many stereotypes as I need or add a metaclass per stereotype. For example, I can add a Class metaclass to the profile and connect to it 2 stereotypes, plane and helicopter or I can add 2 Class metaclasses and connect the plane stereotype to one and the helicopter stereotype to the other. Does it actually make a difference?
Re: 1 or many metaclasses
« Reply #1 on: March 12, 2019, 08:51:44 pm »
There is no difference (in most cases; see Geert's following answer). In fact I use a package for the metaclasses already in use to re-use them.
« Last Edit: March 12, 2019, 09:23:19 pm by qwerty »
« Reply #2 on: March 12, 2019, 08:57:31 pm »
Yes, a number of properties of your stereotype are stored on the metaclass element
(e.g. meaningForwards and meaningBackwards for connectors)
In order to avoid running into issues I recommend using one metaclass per stereotype (the profile helper does it this way as well)
Modesto Vega
« Reply #3 on: March 13, 2019, 04:36:31 am »
Thanks qwerty and Geert
