Author Topic: basestereotypes?  (Read 5005 times)
basestereotypes?
« on: March 13, 2019, 01:42:17 pm »
As we're "plundering" the ArchiMate3 MDG to build the model for our MDG, we've found the attribute basestereotypes applied to stereotype definitions.   What does it mean?  The help system seems to be mute on it.  What's the difference between it and the generalizes attribute?
How do we model this relationship to the "real" stereotype?
TIA,
Re: basestereotypes?
« Reply #1 on: March 14, 2019, 09:03:44 am »
I've only just sat down, but one shows multiple inheritance and the other doesn't. Both are created using generalization connectors.
« Reply #2 on: March 14, 2019, 09:36:38 am »
And you really mean Generalization, not Extension, yes?  I ask for clarification as the QuickLinker doesn't allow Generalization between «stereotypes».
« Reply #3 on: March 14, 2019, 03:06:32 pm »
Yes, generalization. The quicklinker is not correct here.
« Reply #4 on: March 15, 2019, 08:50:07 am »
Really? I just tested two different builds and it does. It's the second item. The reverse (Specialization) is also the only item in the reverse group.
« Reply #5 on: March 15, 2019, 10:51:04 am »
Maybe it depends on which MDGs you have enabled?  I know I have most disabled, I suspect Geert might also.
What's the minimum set of MDGs to see what you're seeing?
Plundering the Archimate 3 MDG, we created a stereotype  Business Behaviour and another Business.  Dragging the QuickLinker from Business Behaviour to Business, We see Substitution, and then the usual suspects:  Abstraction, Dependency, Information Flow, Realization, Usage, Trace.
[Edit: seems to be related to the [X] Filter to toolbox checkbox.  Unmarking it, reveals the Generalization and Reverse Specialization.
 Should that be the case?]
« Reply #6 on: March 15, 2019, 01:59:19 pm »
The toolbox that EA shows for any diagram in a package stereotyped as profile always offers Generalization. So unless you've changed the toolbox it shouldn't matter.
« Reply #7 on: March 15, 2019, 05:27:04 pm »
Ahhh... Our intern had forgotten to do that...
All good now!
« Last Edit: March 15, 2019, 05:47:13 pm by Paolo F Cantoni »
