Author Topic: SysML: Stereotypes in UML Types Dialog  (Read 3023 times)
Arne Krüger
« on: March 14, 2019, 12:17:56 am »
I am looking to remove all non SysML elements from a freshly created EA Model to avoid inadvertent mixing of different MDG elements.
I already have disabled all MDG Technologies other than "Basic UML Technology" and "SysML 1.5". However, a whole lot of Stereotypes remain in the UML Types Dialog which appear to be unrelated to SysML, for instance "cd-rom", "combobox", etc. Where do these come from and is it safe to delete them?
In case my approach is misguided, what is the recommended method to create a "clean" database in EA 14?
Best regards
Arne
Re: SysML: Stereotypes in UML Types Dialog
« Reply #1 on: March 14, 2019, 12:22:40 am »
AFAIK you can safely delete any and all of the stereotypes in the UML Types dialog.
These are a list of "standard" stereotypes that aren't used by MDG technologies.
You probably want to look into perspectives as well to limit your model to SysML
« Reply #2 on: March 14, 2019, 09:11:14 am »
In addition to what Geert has said I would recommend removing the "Configure Stereotypes" from all users. This means they can't type into stereotype fields to add new stereotypes (which often happens accidentally)
