Author Topic: Reporting Connector Information using Document Template  (Read 5820 times)
mmontminy
« on: March 14, 2019, 03:24:38 am »
I am to build a report for several Archimate diagrams. I use the Document Template Designer.
Basically, I want to have the diagram followed by the Elements and their properties and finally the relationships.
In the Diagram section I have selected Element and Connector but left their definition empty.
In the Element section, I have defined what information I want to report on ({Element.Name}, {Element.Type} {Element.Stereotype}, etc.) including some tagged values
In the Connector section, I have done the same ({Connector.Name}, {Connector.Type} {Connector.Stereotype}, etc.)
To my surprise, the Element are included in the report but nothing on the connector.
Anybody can explain that?
I've tried to add fields in the Connector section inside the Diagram section with some success but couldn't include source and target Element of the relationship. "{Connector.SourceColumns}" and "{Connector.TargetColumns}" do not return anything.
I've seen a post where it was proposed to use SQL Fragment to do this.
Any thought on how to report Connector information?
Martin
Martin
ea0323
Re: Reporting Connector Information using Document Template
« Reply #1 on: April 14, 2023, 08:22:48 pm »
Hi, I am having the same problem...Can you give me a tip how to solve
Regards
Greg
Ad "
« Last Edit: April 14, 2023, 08:25:06 pm by ea0323 »
