Author Topic: quick link in excel  (Read 7150 times)
OpenIT Solutions
quick link in excel
« on: June 19, 2012, 07:38:10 pm »
Anyone tried copying a quick link in a supplied mdg file such as the bpmn mdg into a seperate csv file for editing in Excel ?
When i open in Excel its treated as one record, ie all on one row. The record separator (
) seems to be ignored.
Any suggestions on a fix so i can edit the quick link easily in Excel ?
Jon.
Re: quick link in excel
« Reply #1 on: June 19, 2012, 09:44:09 pm »
No "quick" solution.
You can use Notepad++ to pre-/post-process the record separator from &xa; to \n and back. No chance without this step.
You can also change ";" to "\t" (tab) so copy-paste works with either spreadsheet.
Excel is picky and inconsistent regarding separators. Somewhere (in the past) it was possible to specify the separation char. OpenOffice is much easier to handle here.
OpenIT Solutions
« Reply #2 on: June 20, 2012, 02:13:28 am »
I tried a search/replace of
 with \n in the csv file i created; still loads as a single row in Excel.
I could be doing something silly with the search and replace - do i just use ctrl-f in Notepad++ select the replace tab and paste in the two string above ? Or do i need to escape \n somehow on the search/replace dialogue ?
Jon.
« Reply #3 on: June 20, 2012, 02:42:38 am »
The ctrl-f in notepad++ has a Search Mode "Extended" down left you need to check. That will handle \n as newline and \t as tab.
(The regex option works similar but should only be used if you are familiar with regular expressions).
« Reply #4 on: June 20, 2012, 05:12:45 pm »
Jon,
On a windows machine you better replace that string with
\r\n (carriage return + line feed)
PS. This is somehow becoming a Notepad++ topic ;D
« Reply #5 on: June 20, 2012, 05:24:39 pm »
Geert is right. Each OS has it's newline-flavour. And windoze uses \r\n.
I guess, sometimes we need to discuss also peripheral topics like this. When working with profiles I found notepad++ a valuable tool: editing like the discussed, conversion of base64, re-indenting, ability to edit large xml...
« Reply #6 on: June 20, 2012, 05:28:30 pm »
I happen to like Notepad++ too.
Here at work I've even written an add-in that allows us to edit postconditions of operations directly in Notepad++.
For historical reasons we use our very own pseudo-code language in postconditions, and the ability to customize syntax highlighting in Notepad++ really made a difference for us.
OpenIT Solutions
« Reply #7 on: June 20, 2012, 07:53:52 pm »
Thank you both. All sorted now.
