Author Topic: legend using with wildcards  (Read 4710 times)
Pegasus
« on: March 27, 2019, 12:30:32 am »
I want to use diagram legend to colorise elements using wildcards, e.g. colorise all elements starting alias with "Analyse #". Does anyone know if this is supported or are fix values only possible.
Pegasus
steen.jensen
Re: legend using with wildcards
« Reply #1 on: March 27, 2019, 09:20:55 am »
It is working with just a word, you dont need the asterix.
I use it for show me all applications that have the word Internet in the Notes field
Sunshine
  • Its the results that count
« Reply #2 on: March 27, 2019, 05:27:10 pm »
When I've used legend I've only seen it behave by colouring values that are equal to the value. It doesn't seem to have any "contains" functionality from what I've seen nor using the usual wild card characters yield any desired results of colouring
Don't know what Steen is going on about as there is no mapping of value in the diagram legend to notes. Maybe he's confused with diagram filters. You can apply a diagram filter that applies a fade, gray-scale or hide to the elements if the field "contains" the value but it doesn't colour. May be that will work for you.
« Last Edit: March 27, 2019, 05:34:47 pm by Sunshine »
Happy to help
steen.jensen
« Reply #3 on: March 28, 2019, 09:53:39 am »
YEs, sorry :P
Its was diagram filter i was using
