Author Topic: Can't use Repository.Execute(..) with VS 2012  (Read 7256 times)
Helmut Ortmann
« on: June 21, 2012, 10:11:13 pm »
I wanted to use the undocumented function Repository.Execute(..). I can't see it with Visual Studio. The other functions are available. In the Object Catalog it's marked gray as opposed to black for the other methods.
Is there a special trick to use this function?
Kind regards,
Helmut
Re: Can't use Repository.Execute(..) with VS 2012
« Reply #1 on: June 21, 2012, 10:30:33 pm »
You can't see it, but you can still use it.
Just type it out in full and it should work.
Somehow this is a kind of "gray area" undocumented operation.
Helmut Ortmann
« Reply #2 on: June 21, 2012, 10:40:11 pm »
Hello Geert,
thanks a lot. I just found the solution. I think a hidden method.
It works!
Kind regards,
Helmut
Ian Mitchell
« Reply #3 on: June 22, 2012, 04:52:05 pm »
What does this 'secret' method do? I can't seem to see it on VS2012 Object browser?
www.eaDocX.com
www.theartfulmodeller.com
« Reply #4 on: June 22, 2012, 08:59:01 pm »
That why it's secret. It is an unsupported, though existing since long time method. You supply a SQL command to update/delete records. See also my scripting book.
