Author Topic: How to get the Lock status - want to use ApplyGroupLock  (Read 4327 times)
Lal
« on: April 18, 2019, 01:08:53 am »
I want to check the lock status of an element before applying a group lock using ApplyGroupLock.
How to check if group lock is already applied?
My understanding of the lock state is that
1. "No lock, general editing allowed" : Locked = false
2. "Full lock, no-one may edit": Locked = true
3. "User lock, locking user may still edit":  ApplyUserLock() applied
4. "Group lock, locking group may still edit":ApplyGroupLock() applied
Is this correct?
Re: How to get the Lock status - want to use ApplyGroupLock
« Reply #1 on: April 18, 2019, 06:11:28 am »
It all depends on whether you are using Require User Lock to Edit or not.
« Reply #2 on: April 18, 2019, 09:34:23 am »
In this case it's not being used. If you're using "Require User Lock to Edit" then there are no group locks.
Lal
« Reply #3 on: April 18, 2019, 05:31:42 pm »
      What I am trying to do is to lock a requirement so that a user from the same group cannot change it.
The script is part of a workflow to do some checks before locking the requirement.
Do I have to use both "Locked = True" and ApplyGroupLock() ?
Lal
