Author Topic: Programmatic Interface Customization  (Read 4082 times)
mkrallinger
« on: June 26, 2012, 09:48:10 pm »
Hello!
Is there a possibility to programmatically change the layout of the toolbars (e.g. based on the content of a XML file). The functionality should be similar to the "Interface Customization Wizard".
Thanks for the help!
Best regardsl,
Markus
Re: Programmatic Interface Customization
« Reply #1 on: June 26, 2012, 10:28:03 pm »
No. At least AFAIK. You could probably tweak the registry. Depends actually on your use case. If you do so it's required that EA is restarted in order to have the changes visible.
mkrallinger
« Reply #2 on: June 27, 2012, 12:26:44 am »
Oke.
I can just manipulate the toolboxes, thats good enough for me.
Best regards,
Markus
