Author Topic: Enterprise Architect Automation API documentation  (Read 35563 times)
ApelManu
« on: June 27, 2012, 10:17:36 pm »
Hi folks,
does anyone know a good documentation for the Enterprise Architect Automation API?? Looking for days but haven’t found a good documentation.
Thanks Manu
Re: Enterprise Architect Automation API documentat
« Reply #1 on: June 27, 2012, 11:27:53 pm »
Manu,
Have you read the manual?
Each and every property and operation is documented in the help file.
If that doesn't suffice, you can buy these e-books:
http://leanpub.com/ScriptingEA
http://leanpub.com/InsideEA
ApelManu
« Reply #2 on: June 28, 2012, 12:11:17 am »
Hi Geert,
thanks for the fast answer. What manual you talking about? Found this pdf document “enterprise_architect_sdk” with a lot of information.
I was thinking about to buy this books, are they worth it???
Thanks Manu
Makulik
« Reply #3 on: June 28, 2012, 12:20:46 am »
I guess Geert is talking about this manual:
http://www.sparxsystems.com/enterprise_architect_user_guide/9.3/automation/automation_interface.html
This is also available in your EA Help-Documentation installed with the product.
« Reply #4 on: June 28, 2012, 01:09:03 am »
I was indeed talking about the manual as in RTFM  ;)
« Reply #5 on: June 28, 2012, 06:14:55 am »
You can download a sample of the book...
Pace17881
Re: Enterprise Architect Automation API documentation
« Reply #6 on: October 16, 2018, 09:49:14 pm »
Thank you all for the help. I solved my problem.
The COM API delivers all elements from a model, except the elements that are not connected to a diagram. Problem are the connectors. I have to figure out whether the connection ends points to an element that is connect to diagram or not. There is no need send an sql command.
« Reply #7 on: October 17, 2018, 01:29:49 am »
Does that leave an open question? If so, you should not end with that very last sentence.
michielper
« Reply #8 on: May 25, 2020, 09:34:34 pm »
Hi folks,
Thanks Manu
https://sparxsystems.com/resources/user-guides/15.1/automation/automation.pdf
