Author Topic: Data Modeling - add tagged value to column  (Read 2561 times)
mooremj
« on: May 04, 2019, 12:21:11 am »
HI,
I am using EA for data modeling, I would like to add tagged values to the table and column properties.  I can successfully add them to the table properties, but not to the column.
Is there a way to do this?  If not, is there another way for me to associate information with columns.
Jane
Re: Data Modeling - add tagged value to column
« Reply #1 on: May 04, 2019, 03:13:07 am »
Why can't you add tagged values to columns?
if you want to do this structurally you should look into extending the EAUML::Table and EAUML::Column stereotypes with your own stereotypes in a UML Profile.
Then add those in an MDG.
mooremj
« Reply #2 on: May 04, 2019, 06:01:01 am »
I am pretty new to Enterprise Architect....I can't find any option to add a tagged value at the column level, I have tried from the properties window and from the project browser.  I will look into extending the EAUML::Table and EAUML::Column stereotypes.....this is new to me too :-(
Jane
« Reply #3 on: May 04, 2019, 06:21:39 am »
You can to open the tagged values window. Once you select something that allows tags you can edit them in that window. Most elements also have a tab in their properties where you can do the same. EA's GUI is a bit strange. Like from the planet Sparx in the outer vicinities of the Horse Head nebula.
mooremj
« Reply #4 on: May 06, 2019, 11:18:52 pm »
Thanks for your help.
I have found the EAUML::Table stereotype but I cannot find the EAUML::Column stereotype.
Also, I have tried everything I can think of and I cannot get any tagged values to associate with a column.
Is it possible that I have the functionality turned off somewhere?  Or, is it possible that tagged values are just not available on columns when creating data models?
Jane
