Author Topic: Get all elements at the other end of DiagramGate  (Read 3266 times)
ankur
« on: May 08, 2019, 06:44:39 pm »
I am trying to extract all the elements connected to the other end of the DiagramGate in Sequence Diagram using EA API in C#.
Till now, I am calling out all connectors from a diagram and extracting the "Supplier" from the Connector where the "Client" type is MessageEndpoint. Something like this:
foreach (Connector singleConnector in singleDiagram.Connectors )
    if (Repository.GetElementByID(singleConnector.ClientID).Type.Equals("MessageEndpoint"))
        Element theElement = Repository.GetElementByID(singleConnector.SupplierID);
But I want to read all the elements connected to the given DiagramGate (independent of diagrams) using EA API.
I can see the Relationships when I right click the DigramGate and then go to Properties -> Special Actions -> Related -> Links.
Is there a possibility to extract the "Relationships" using EA API ?
Thanks in advance.
Ankur
« Last Edit: May 08, 2019, 07:01:48 pm by ankur »
Re: Get all elements at the other end of DiagramGate
« Reply #1 on: May 08, 2019, 07:11:09 pm »
I guess the easiest is to run a custom SQLQuery for that.
