Author Topic: Test Description  (Read 3157 times)
Martin Robinson
Test Description
« on: June 27, 2012, 11:53:51 pm »
I can't seem to get linked documents to work. I am modifying a Test Description. I can add characters and these are saved correctly.
1) If I link to a zip file using the link icon, it lets me select a file, but then nothing is entered into the Test Input box.
2) If I drag the file into the box, it is shown and can be double-clicked to view/edit, but as soon as I navigate away from the Test Input then the link is lost, even though other changes are correctly saved.
What am I doing wrong?
Re: Test Description
« Reply #1 on: June 28, 2012, 03:39:10 pm »
Martin,
I think you first need to write some text, then select that, and only then use the link icon to make it a hyperlink.
Martin Robinson
« Reply #2 on: June 28, 2012, 08:29:18 pm »
Thanks for the suggestion Geert - it has made some improvement, but I'm not there yet. I now have text that looks like a hyperlink (coloured blue and underlined and cursor changes to a 'hand'), but when I click on it nothing happens - it does not open up the linked document (I've tried linking to an xls file and an rtf file).
Martin
