Author Topic: shapescript with fixed height  (Read 3420 times)
« on: May 10, 2019, 05:51:32 pm »
I'm looking for a way to make an element with a fixed height.
It should only allow to be elongated, but not change in height.
Anyone know if this is possible, and how to do it?
Re: shapescript with fixed height
« Reply #1 on: May 10, 2019, 10:40:56 pm »
You will need an add-in to observe size changes. Haven't heard of any property to allow that else.
« Reply #2 on: May 11, 2019, 03:24:27 am »
A found a possibility to make it look lik you can't change the height.
Use a border layout, add a subshape north, and set the preferredHeight property
If you then resize the element the visible height doesn't change.
Unfortunately that didn't help with my use case.
