Author Topic: using the SYSMOD Plugin / anoying activation each time  (Read 3826 times)
DreiBaer
« on: May 14, 2019, 05:53:17 pm »
I have installed the SYSMOD Plugin and I am trying to use it.
The installation process was a little bit confusing, because I didn't see the plugin available in any of the menus. After two days I found it in the "find toolbox item" search dialog. I activate it and after that I could use it. But only as long as the diagram was open. Opening a new diagramm or closing and opening it again the activation process has to be done again.
Is there any way to permanently mark the Plugin / usgae in Tollbox active?
Best Regards
DreiBaer
Re: using the SYSMOD Plugin / anoying activation each time
« Reply #1 on: May 14, 2019, 06:04:13 pm »
Have you tried contacting LieberLieber directly?
DreiBaer
« Reply #2 on: May 20, 2019, 08:40:55 pm »
No I'm sorry. I thought this is an EA forum, therefore I can get answers to all the questions arround EA.
« Reply #3 on: May 20, 2019, 09:52:22 pm »
It is, but it is a user forum, and I suspect there aren't to many users that can hep you with that. The people from LieberLieber to occasionally come here as well, but I think it will be much faster if you contact them directly.
