Author Topic: Database relaed tagged values  (Read 4248 times)
MaXyM
« on: May 24, 2019, 08:03:37 pm »
There are tagged values related to database, being applied to all db objects:
- Owner (a schema)
- DBVersion
- Tablespace
Before v15 those tagged values were found in tagged values window. But not anymore. On top of that I found the current state is inconsistent:
See image:
Those tagged values are not available in Properties/Tags (bottom left), but are in Special Action/General/Tags (top rights).
In addition to this those tags are exposed as properties (bottom right), and schema itself (Owner) is exposed in Special Action/General/Table detail.
BTW, if I change Owner available in Special Action/General/Table, it is not enough to apply changes to synchronize this change with other places (even to Special Action/General/Tags). It's needed to press OK, allowing to store/refresh data to/from underlying database. Saying that I'm emphasize that using "Apply" button is not enough which is I consider to be a bug.
« Last Edit: May 24, 2019, 08:06:11 pm by MaXyM »
Amelia28
Re: Database relaed tagged values
« Reply #1 on: July 06, 2019, 03:18:49 am »
Enterprise Architect has enriched the basic concept of Tagged Values with its powerful structured Tagged Value facility. To assist you when entering data, the values can be restricted using user interface controls such as drop-down lists, spin controls, date selectors and many more.
find more information on :
https://sparxsystems.com.au/enterprise_architect_user_guide/14.0/modeling_tools/thetaggedvaluestab.html Dafont Showbox Adam4adam
« Last Edit: July 26, 2019, 06:50:39 am by Amelia28 »
