Author Topic: Publish from model to .doc from external script?  (Read 5754 times)
F@lk
« on: May 28, 2019, 12:41:38 am »
Is there something like this?
c:\temp\cool_tool.exe /from=my.eapx /to=documentation.doc
My build system should generate the docs from EA model DB file per script.
Thanx in advance
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
Re: Publish from model to .doc from external script?
« Reply #1 on: May 28, 2019, 12:57:31 am »
It is something wrong in the question: you are not considering that an EAP file could include several root nodes (not just only one), and documentation is supposed to be for a selected package/element. So, if you pretend to generate a .doc from a model, you should also pass "as parameter" the package you need to document.
I think there is no tool for that, but theoretically, it could be written as an external app.
« Reply #2 on: May 28, 2019, 05:46:57 am »
No, I've never heard of a tool that does that either.
But you can indeed write one yourself. It could even be as simple as a VBScript or something like that.
timoc
« Reply #3 on: May 28, 2019, 06:44:21 pm »
I was wondering about something like this myself.
Can you use EALite to generate (HTML) documentation as part of an automated build process?
« Reply #4 on: May 28, 2019, 07:10:26 pm »
They limited the usage of the API from EA Lite quite a bit a few years ago.
Not sure if this also means you can't generate the a HTML report, but I wouldn't be surprised if it was.
Why would you need EA Lite for that?
timoc
« Reply #5 on: May 28, 2019, 09:38:06 pm »
Makes it easier to put into a headless triggered build chain, like Jenkins, without having to make a license available. For automatically publishing models etc.
timoc
« Reply #6 on: May 28, 2019, 09:50:16 pm »
You might find something helpfull here:
https://github.com/docToolchain/docToolchain/tree/master/scripts
Ralf
« Reply #7 on: June 02, 2019, 07:44:49 pm »
thanx @timoc for mentioning docToolchain here.
I am one of the core committers to docToolchain.
Yes, docToolchain contains a script which starts EA headless and exports all diagrams and element notes.
I use it to generate several types fo documentation output, but to get .docx output, we use AsciiDoc as Markup inbetween.
So, we write docs in AsciiDoc and reference the diagrams exported from EA in these docs. The AsciiDoc files can then be converted to HTML, PDF and DOCX.
Here is the documentation for the exportEA step: https://doctoolchain.github.io/docToolchain/#_exportea
