Author Topic: Multiple archiate 3 Application components converging to the same component  (Read 4232 times)
SJ
I am developing a roadmap between Baseline to the Target architecture.
If there are multiple (legacy )application components converging to the same (Target ) component, how can we depict it in  a roadmap.
Can I draw an association between each legacy component to the Target component, with a source to destination arrow or is there some way better.
Thanks for all the help provided in this forum folks.
SJ
Glassboy
An association would be the most appropriate but ArchiMate doesn't give you the option of having directional arrows for an association.
Sunshine
  • Its the results that count
From the ArchiMate Spec and the book "Enterprise Architecture at Work" you can use plateaus to represent the baseline and target architecture with triggering between them. You can either put the application components inside the plateaus on the diagram or create a aggregation relationship between the plateau and the application component.
Happy to help
SJ
I can show an arrow by selecting the 'direction' in the properties tab for an association.
Sure, but is it still ArchiMate then?
Glassboy
Or more to the point will that cause issues with the weird ArchiMate shapescript?  (Actually I suspect the user is using a UML association between two ArchiMate elements).
