Author Topic: Function of “Partition” (Alias) field in Activity?  (Read 4792 times)
« on: May 31, 2019, 03:47:07 pm »
We've started using the Alias field in Elements in a very concerted way.
Every vertex should be able to have an alias, shouldn't it?  Wrong!  It seems the Activity element type has a Partition field instead of an Alias.  Sparx has apparently hijacked its own field.  I tried to find out about the semantics of it, but it eluded me.  qwerty's excellent Inside EA eBook is also silent on the topic.
Can anyone shed any light?
TIA,
[Edit: corrected object to element.]
« Last Edit: June 01, 2019, 11:09:29 am by Paolo F Cantoni »
Re: Function of “Partition” (Alias) field in Activity?
« Reply #1 on: June 01, 2019, 07:20:03 am »
Well, since you talk about Activity and Object (what is an activity object by the way?) there's an object element in the activity toolbox which has its (so-called) Role property stored in t_object.alias. The Requirements use the stereotype as type. There's more for sure. Inconsistency, your name is Enterprise Architect.
The UML 2.5 specs talk about alias only in connection with namespaces and element imports.
« Last Edit: June 01, 2019, 07:23:58 am by qwerty »
« Reply #2 on: June 01, 2019, 11:10:57 am »
My bad, I meant element (for object).  Original post corrected.
However, your point about inconsistency is taken.
« Reply #3 on: June 01, 2019, 05:47:36 pm »
Hmm. Where is that Partition property? I'm looking into V13.5.
« Reply #4 on: June 02, 2019, 08:58:59 am »
It's in the new multipurpose Element Window. I checked and it's in v14 and v13.5.  I thought at first it was a v15 special, but it's been there for a while, just not noticed (at least by me).
« Reply #5 on: June 02, 2019, 10:07:57 am »
Ah yes. Sigh. The properties. Not the properties :-/
Just look into your signature. All said.
billf62
« Reply #6 on: June 14, 2019, 04:31:45 am »
I noticed that just today.  It does appear 'hijacked' in the docked Element Properties window, but it's still there in the old-fashioned Properties/General screen (Use ALT + Enter to access).
