Author Topic: Generate a report in EA using the command line  (Read 4764 times)
Risikat
« on: July 09, 2012, 11:15:24 pm »
How do you access EA using the command promp. Most importantly generate html or csv reports from the command prompt instead of having to go into EA to do it.
« Last Edit: July 10, 2012, 01:16:54 am by RisikatSeriki »
Re: Generate a report in EA using the command line
« Reply #1 on: July 09, 2012, 11:51:03 pm »
You can write a simple script that uses the API to perform s single task.
Risikat
« Reply #2 on: July 10, 2012, 08:03:59 pm »
Which is the better script to write VBScript or JavaScript. How do you go about running it in the command window
« Reply #3 on: July 10, 2012, 09:05:19 pm »
I would use C#, but I guess that is kind of a personal preference.
« Reply #4 on: July 10, 2012, 11:45:04 pm »
:-) indeed. I'd prefer Perl...
« Reply #5 on: July 11, 2012, 09:22:41 am »
Presumably you're talking about the Windows command prompt? Sorry, not possible: you can only run scripts in the Scripting window within EA. The answer is to create your own executable and run that. This page in the help file will get you started in VB6, C#, Delphi or Java, but any language capable of generating ActiveX Com clients can be used.
