Author Topic: Exception when creating a repository from external program.  (Read 3846 times)
jepessen
I've created a C# console application that uses Interop.EA.dll in order to open a Enterprise Architect project. I'm using Visual Studio 2019 and Enterprise Architect 13.
I've added the .dll in the references:
This is the class where I'm trying to open the repository:
using System;
using System.Collections.Generic;
using System.Text;
namespace EARedmineRequirementsConnector
    class EAConnector
        private EA.Repository repository;
        [Obsolete]
        public EAConnector(Options options)
            try
                repository = new EA.Repository();
                repository.OpenFile(options.EAFilePath);
            catch (System.IO.IOException)
                Console.WriteLine("Cannot open file: " + options.EAFilePath);
            catch(ExecutionEngineException e)
                Console.WriteLine("Exception: " + e.Message);
When I run the program, I've an exception when creating the repository.
I don't understand which exception is and why I've this.
How can I create correctly the repository in order to open an existing file from an external application?
Re: Exception when creating a repository from external program.
« Reply #1 on: June 05, 2019, 12:11:07 am »
Not sure what causes it, but you might find some answers here: https://stackoverflow.com/questions/967044/system-executionengineexception-failure
jepessen
« Reply #2 on: June 05, 2019, 06:45:36 am »
Ok I've found the error: I was using a .NET Core project instead that a .NET Framework project.
