Author Topic: External includes in Ea Javascript engine?  (Read 6814 times)
timoc
« on: June 05, 2019, 04:30:33 pm »
Is there a way to include scripts from the file-system in the (new?) Javascript engine? or do they have to be imported?
Re: External includes in Ea Javascript engine?
« Reply #1 on: June 05, 2019, 04:50:53 pm »
I think you'll need to import them and use !Include
PS. If you have a lot of scripts to import, I wrote an script importer function in VBScript, see here: https://github.com/GeertBellekens/Enterprise-Architect-VBScript-Library/tree/master/Framework/Tools/Script%20Management
timoc
« Reply #2 on: June 05, 2019, 06:28:00 pm »
Thanks i will look at it. Its not a matter of import as such, its a matter of the development cycle overheads of having to repeatedly import external dependencies.
Out of curiosity, is there a HTML DOM/view attached to the JS engine somewhere inside EA?
« Reply #3 on: June 05, 2019, 06:58:50 pm »
Not sure what you mean by that. Can you explain?
timoc
« Reply #4 on: June 05, 2019, 08:23:57 pm »
I am trying to instrument the script with some logging output using console.log(). This does not work because it seems to be tied to a HTML DOM , so i wondered if EA is able to render HTML in a "popup" window from a script.
Also, In the script engine description it can be "called from report document templates to populate reports".
I want to develop in Javascript and render HTML, as it is easier to test with outside of EA, and there is alot of off the shelf scripts for HTML dom manipulation.
Third,
« Reply #5 on: June 05, 2019, 08:52:24 pm »
the "called from report generator" probably point to the script fragments in RTF templates.
if you want logging you can use either Session.Output (for debugging) or Repository.WriteOutput (for status information)
You can definitely create HTML from a script, and then show that html file using your favorite browser, but your script isn't executed in a browser context.
Pretty much anything you can do outside of EA as a standalone script is possible from inside EA.
timoc
« Reply #6 on: June 06, 2019, 05:59:59 pm »
For anyone else interested, this is how i extended the logging function to implement a browser console.log():
!INC EAScriptLib.JScript-Logging
var console = new Object();
console.log = function( message ){ Session.Output( _LOGGetDisplayDate() + " [JS Console]: " + message ); };
