Author Topic: Stereotypes assigned to an item/object  (Read 4996 times)
Modesto Vega
« on: June 05, 2019, 06:00:48 pm »
Could somebody please remind me where about does Sparx EA store the stereotypes associated with an item/object when the item/object has more than one stereotype associated with it? t_object.stereotype does not appear to be only place. The reason for the question is that, after and import, I have 2 items/objects with 3 stereotypes associated, 2 of which don't seem to go away no matter what I do.
Also how do I remove unwanted stereotypes from t_stereotype?
Re: Stereotypes assigned to an item/object
« Reply #1 on: June 05, 2019, 06:16:08 pm »
t_xref
where xref.name = Stereotypes'
and xref.Client = item.ea_guid
timoc
« Reply #2 on: June 05, 2019, 06:19:47 pm »
You can manually use the Configure->UML type dialog. I think you have to remove or disassociate elements from the type before you can delete it.
Modesto Vega
« Reply #3 on: June 05, 2019, 06:26:33 pm »
t_xref
Of course!!!  Thanks Geert.
This is the 1st thing I tried and it does not appear to work, they keep reappearing even when I don't seem to have any items/associated with them (although I have not checked the full repository).
