Author Topic: Can someone explain the difference between an event and a trigger?  (Read 4657 times)
mse
Autosar refers to events and triggers in its UML profile, and I'm confused really what the difference is between the two. It seems like a trigger can be of Call, change, timed, or signal. Those are clear to me, however, why would we need an extra event for all this? It seems like a trigger is the event.
Re: Can someone explain the difference between an event and a trigger?
« Reply #1 on: June 13, 2019, 11:32:46 pm »
From the UML 2.5 specs:
13.4.11 Trigger [Class]
13.4.11.1 Description
A Trigger specifies a specific point at which an Event occurrence may trigger an effect in a Behavior. A Trigger may be qualified by the Port on which the Event occurred.
Read more on p. 291 chap 13.3.4
« Last Edit: June 13, 2019, 11:35:00 pm by qwerty »
