Author Topic: VC Issue locked elements  (Read 3229 times)
nxtControl
« on: June 14, 2019, 01:02:58 am »
Hello i've locked packages in my project what i want to force unlocked.
The user who as checkout is not available any more.
How can i unlock / force checkout ?
Re: VC Issue locked elements
« Reply #1 on: June 14, 2019, 01:06:41 am »
Use the version control system to remove the check-out, and then synchronize the status of the packages from EA.
nxtControl
« Reply #2 on: June 14, 2019, 01:17:10 am »
This was what i tried.
Log says:
Resynchronizing status of the selected version controlled package, with its Version Control Provider.
   Package: 'Editors' - WARNING: Package marked as 'CheckedIn', but XMI file reported as 'Out To Other' - cannot synchronize to this state.  Package 'CheckedOutTo=' value remains empty.
So i'm not able to unlock the packages. What do i wrong?
« Reply #3 on: June 14, 2019, 01:23:28 am »
Go into your version control system and remove the check-out from the file.
Then you can do a synch.
nxtControl
« Reply #4 on: June 14, 2019, 01:36:14 am »
Thank you. Solved.
