Author Topic: Reuse problems in activity diagrams  (Read 4410 times)
Volkan
« on: June 14, 2019, 11:40:28 am »
When I draw an activity diagram, I reused two existing actions by a drag-and-drop. But the control flow between the two actions is copied, too. I do not want to reuse the control flow. But when I deleted the control flow, the original flow was also deleted. Is there a way to figure this out? Thank you very much!
« Last Edit: June 14, 2019, 12:05:07 pm by Volkan »
Re: Reuse problems in activity diagrams
« Reply #1 on: June 14, 2019, 01:32:24 pm »
You can't and shouldn't reuse actions. An action exists only in the scope of it's activity and is not supposed to be re-used.
The flows from and to actions are properties of these actions.
You can duplicate actions if you want by copy / Ctrl-Shift-V
Volkan
« Reply #2 on: June 14, 2019, 03:06:12 pm »
Hi Geert, Thank you very much for the reply!
