Author Topic: ArchiMate3 - Child diagram not removable  (Read 4507 times)
bvdl
« on: June 17, 2019, 06:11:54 pm »
When I want to remove the child diagram from an ArchiMate3 element (the glasses in the lower right corner on a diagram) then I use the context menu: New Child Diagram > Select Composite Diagram > "<none>". The glasses disappear, but when I refresh the diagram after saving then the glasses are back.
Re: ArchiMate3 - Child diagram not removable
« Reply #1 on: June 17, 2019, 09:26:04 pm »
That looks like a bug.
The workaround in the old days was to create a new diagram, set it as composite, and then delete that diagram.
« Reply #2 on: June 17, 2019, 09:55:26 pm »
Workaround :
Did you try clicking New Child Diagram -> Composite as shown below to remove the composite ?
RoyC
  • Read The Help!
« Reply #3 on: June 18, 2019, 12:09:16 pm »
If an element is set to have a composite diagram, it automatically picks up the first diagram in its own parent Package (if there isn't one, it creates a new one there). As Arshad says, toggle the 'Composite' option off.
Best Regards, Roy
