Author Topic: sizing elements  (Read 4919 times)
GrahamL
sizing elements
« on: June 17, 2019, 11:04:32 pm »
Hi
Simple question :
Is there a way to size an element according to its contents?
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
Re: sizing elements
« Reply #1 on: June 17, 2019, 11:55:57 pm »
I think no. Except if the element is actually a package and "the content" is the elements or packages that it contains.
But you can create a script that resize the elements in a diagram according to the size of the text. Have in mind the zoom percentage could affect you.
Re: sizing elements
« Reply #2 on: June 18, 2019, 01:20:02 am »
Sizing by what means?
Takeshi K
    • Sparx Systems Japan
Re: sizing elements
« Reply #3 on: June 18, 2019, 10:02:01 am »
If I understand correctly, ALT+Z shortcut is useful.
(For all objects in a diagram, Ctrl+A and then ALT+Z).
You can call this feature from the Ribbon, but I forget where it is.
t-kouno
Re: sizing elements
« Reply #4 on: June 18, 2019, 02:27:55 pm »
From context menu.
Right-click on selected elements in a diagram | Autosize (available only when multiple elements are selected)
« Last Edit: June 18, 2019, 04:05:41 pm by Arshad »
Takeshi K
Re: sizing elements
« Reply #5 on: June 18, 2019, 03:28:03 pm »
Hi all,
I can find the command in the following Ribbon:-)
Layout ribbon | Diagram panel | Select button | Autosize Selected Elements (in version 15)
Layout ribbon | Diagram panel | Edit button | Autosize Selected Elements (in version 14.1)
t-kouno
