Author Topic: Traceability information Missing for Extended Class (UML)  (Read 15014 times)
aero_g
Hi all,
Hope you can provide some help.
I have used the Extension relationship within the Metamodel Toolbox to extend Class 1 from metaclass Class (UML extension) so that Class 1 is a subtype of the Metaclass Class.
However, in the traceability window, when I select Class 1, I am unable to see the link/association to the metaclass from where it was extended from.
I have looked into the example provided by EA and the example uses an association relationship with a stereotype of <<extends>>. With that example, I am able to view the traceability information and am able to see that Class 1 is  Associated to Class.
For UML, is there a difference between using association relationship with <<extends>> stereotype (as in the EA UML stereotype example) vs. using the Extension relationship within the Metamodel Toolbox?
Many thanks for your help!
« Last Edit: June 18, 2019, 04:21:00 pm by aero_g »
