Author Topic: programmatically search for Requirements  (Read 3437 times)
ngong
« on: June 22, 2019, 11:08:10 pm »
I can manually search for Requirements in the Find in Project dialog of EA by selecting Requirements and Requirements in the first two fields an leave the third one empty. Then I get all requirements (gt 6000 in my case).
If I am entering
set rqs=Repository.GetElementsByQuery("Requirements","Requirements")
in a script I get a collection size of just above 200.
Where does the difference come from and what is the easiest way in VBScript to get a collection of all?
Rolf
Re: programmatically search for Requirements
« Reply #1 on: June 23, 2019, 06:48:22 am »
Probably a
Repository.GetElementSet("SELECT * FROM t_object WHERE object_type='Requirement'", 2)should do it.
« Reply #2 on: June 24, 2019, 10:00:04 am »
If I am entering
There's no parameter for the category in GetElementsByQuery. So the equivalent of your GUI search would be:
set rqs=Repository.GetElementsByQuery("Requirements","")Which means that you're going to get the same result as qwerty's suggestion. Although that also has the advantage that you're not going to be impacted by a change in the search definition or a new search named 'Requirements'.
