Author Topic: Properties dialog not shown on new message connector in sequence diagram  (Read 3718 times)
flexjoly
  • Divaeloper
    • Female Divaeloper
In this video: https://sparxsystems.com/resources/demos/sequence/Sequence_diagram.htm when a message connector is added/drawn the properties dialog opens directly so you can enter the message-description.
In v14.1 and even in v15RC this dialog does not popup when adding a new message/connector.
After a new connector, the target-lifeline is selected and the property-window shows the properties of this lifeline in stead of the new connector.
So I need to select the new connector so I can add the message-description in the property window. F2 does not work on this connector type. Context menu > properties won't show anything.
The option 'edit connector on new' is checked. I even tried to uncheck, close diagram, check option again and open diagram.
I searched everywhere, tried to reset EA to defaults etc. But I cannot get it to work as shown in the video.
I tried with auto-numbering off, but that also does not help.
What am I doing wrong? I hope someone can help me out here. It is pretty annoying, also because a new connector is deselected.
Thanks in advance, flexJoly
EA has changed from property dialogs to docked property windows.
The docked property window has the same properties as the old dialog.
flexjoly
  • Divaeloper
    • Female Divaeloper
Hi Geert,
Thanks for your quick reply. That does explain a lot!
But then adding a message is not so quick and user-friendly anymore:
- draw connector
- select connector (because it is NOT selected by default after adding)
- move mouse to property window and click
- start typing etc
- click on save button (else it is not saved into the diagram)
This is a lot of repeated handling for a simple connector.
It would be much better if:
- connector is selected by default
- the property window is focussed, so you just can start typing
- click enter to save the changes
Greetz, flexjoly
I agree. Make sure your comments reach Sparx as well by sending in a feature request.
