Author Topic: Creating SysML diagrams with automation interface  (Read 3325 times)
Svendsen
« on: June 27, 2019, 03:32:09 pm »
Hey guys,
as said in the documentation for the diagram class, valid types are:
-Activity
-Analysis
-Component
-Custom
-Deployment
-Logical
-Sequence
-Statechart
-Use Case
Is it possible to add SysML types like BlockDefinition diagrams?
Greets Sven
Re: Creating SysML diagrams with automation interface
« Reply #1 on: June 27, 2019, 03:40:21 pm »
Sven,
Technically SysML diagrams are one of one of the listed type, but with a stereotype (check the database to make sure which base type is used)
You can either create the base diagram type, and then set the stereotype, or you can (probably) create it directly by passing the fully qualified meta type to the AddNew() operation.
That would be something similar to "SysML1.1::BlockDiagram"
Svendsen
« Reply #2 on: June 27, 2019, 03:43:47 pm »
Sven,
Hello Geert,
thanks for your fast reply. I will give it a try
Sven
Svendsen
« Reply #3 on: June 27, 2019, 04:24:51 pm »
In case of the Block definition diagram, the type "SysML1.4::BlockDefinition" worked for me.
Greets
