Author Topic: Upgrade to latest version of Prolaborate  (Read 31714 times)
Prolaborate Support
  • Prolab Moderator
    • Visit us
« on: July 02, 2019, 11:29:05 pm »
Please follow these steps to upgrade from V3.2.6.x to V3.2.7.x:
https://www.sparxsystems.com/forums/smf/index.php/topic,44219.0.html
Please follow these steps to upgrade from V3.2.5.x to V3.2.7.x:
Please follow these steps to upgrade from V3.2.4.x to V3.2.7.x:
  • It is recommended to take a backup of Prolaborate installation folder and database
  • Visit this link and download Prolaborate and Pro Cloud Server V4.1.44 (PCS) Installers using the credentials in your Pro Cloud Server document
  • Install PCS and restart Sparx Systems Professional Cloud service.
  • Stop all Prolaborate services and processes (All services and processes starting with Prolaborate and websocketd process) from Task Manager
  • From the downloaded Prolaborate folder, run Setup.exe as administrator and complete the installation. Note there would be a brief wait time after you click on Next.
  • Check Prolaborate Versions in the Health Checks page. If there is a mismatch between current and latest versions, run the latest database schema on the Prolaborate database from the Release Notes page based on the database server used for Prolaborate.
Note:
  • (Critical) If you are using the Prolaborate macro for Confluence, schedule your upgrade of Prolaborate and the macro together. The latest version of Prolaborate is compatible with only the latest version of the macro.
Please follow these steps to upgrade from versions lower than 3.2.4 to 3.2.7.x:
Note:
  • (Critical) After the upgrade of macro, do not change Default Repository. If you want to change, all the EA information that has been embedded using the macro needs to be reconfigured.
  • As the profiles in Create Elements are linked with the profiles in Modeling languages, the standalone profiles will not be available anymore.
« Last Edit: June 24, 2020, 12:00:09 am by Prolaborate Support »
