Author Topic: Can I export a package with statuses  (Read 5041 times)
WillieBoykin
« on: July 05, 2019, 07:45:24 pm »
What Makes For The Best Cordless Drill?
Looking for the best thing has never been easy; finding the best cordless drill is also a hard task for any user. However, if you can answer some of these questions, you might succeed in this task. The first important thing is: What do you need in a drill? Secondly, how much power do you need? And will you need to use cordless drill regularly?
✫✫✫ Read More: Best Cordless Drill - Top Rated Cordless Drill On The Market
If you are a regular user, you must make sure that your drill is reliable and won’t run out of battery power quickly. It is better to have a nail gun for nailing.
Sometimes, there are some excellent drills for your needs, but they don’t have a long battery life. In that case, you can invest in multiple batteries to make sure you will always have power. To ensure that your drill works well and quickly, you will want to focus on the laser level for heightening accuracy.
Look for a device that can produce up to 300 unit watts of power and that comes with a ½-inch sleeve chuck.
Best battery for cordless drills
The most important thing in terms of the top rated cordless drill is its battery, including how long it will last. Most cordless drills have high power and can last at least a few hours but if you’ll need to work for a full days, you’ll need to charge the battery.
Nowadays, due to technological innovation, it is not hard to find a battery that can last for an entire working day. There are a lot of brands that produce tools with outstanding battery life. Some batteries can last for up to 24 hours.
Is the battery interchangeable?
The answer to this is “no.” Each manufacturer designs its drills differently, and it is best to use the battery that aligns with the brand.
Cordless and corded drills comparison
You might be a little confused as to which is better – corded or cordless drills? It mostly depends on your specific requirements and tasks. Do you need the drill to move quickly and freely in hard-to-reach places? Or do you need a tool with max torque and excellent output? Your needs are the priority.
A corded drill is perfect for heavy-duty work. It can plug directly into a power source, which means that you can tap into more power and produce max torque. Meanwhile, a cordless drill is very compact and easy to move anywhere you want.
☞☞☞ Get More Info: Top Rated Cordless Drill: How to Choose The Best Cordless Drill
To learn more about the greatest cordless drill, take a look at some cordless drill reviews from experienced users for reliable information.
« Last Edit: July 25, 2023, 02:15:35 pm by WillieBoykin »
Re: Can I export a package with statuses
« Reply #1 on: July 05, 2019, 08:13:40 pm »
Use the option Publish | Model Exchange | Export XML
This xmi export is basically a dump of all information from that package, so it will also contain the statuses.
« Reply #2 on: July 05, 2019, 09:33:17 pm »
You can create a search (Ctrl-F). There you can even add a filter for the status (and preset it if needed). The search results can be copy/pasted as usual.
