Author Topic: Sort Order of Test Cases in RTF/PDF Report  (Read 4222 times)
lcjaubrey
« on: July 13, 2012, 01:06:37 am »
Is there a way to alter the way EA sorts test cases in a report that I created and generate on a regular basic. If I have ten test cases and I enter a unique number in the NAME field of each test, the generated document list test case 10 after the first test case. I would like the tests to be listed in the oprder they were entered in EA or in sequence, meaning 10 coming after 9.
RoyC
  • Read The Help!
Re: Sort Order of Test Cases in RTF/PDF Report
« Reply #1 on: July 13, 2012, 10:07:15 am »
Name the first 9 tests 01 to 09 - does that help?
Best Regards, Roy
lcjaubrey
« Reply #2 on: July 18, 2012, 12:49:10 am »
But when test 10 is entered, it gets sorted/placed after 01 in the template.
Dermot
« Reply #3 on: July 18, 2012, 09:41:48 am »
Test Case in the RTF are set to do a simple Alpha sort. So an alternate option is to list these using an alpha sequence:
 a), b), c),
« Last Edit: July 18, 2012, 09:42:31 am by Dermot »
