Author Topic: Imported Visio Decision element - converting to BPMN Gateway element  (Read 4668 times)
Bumble
I've imported a Visio model into Sparx via the Microsoft Visio Add in and am attempting to convert 'Activity' elements to BPMN Activity and 'Decision' to BPMN Gateway elements via a VB Script.
My script looks to work for Activity :
currentElement.Type = "Activity"
currentElement.StereoTypeEX = "BPMN2.0::Activity"
currentElement.Update
But for the Gateway update, it is not working (BPMN tab does not appear in Element properties and the element does not display in the Browser)
I've tried various combinations, below is the latest :
currentElement.Type = "Gateway"
currentElement.StereoTypeEX = "BPMN2.0::Gateway"
If someone could point me in the direction of what I'm doing wrong please - that would be fab :-)
Many Thanks
Re: Imported Visio Decision element - converting to BPMN Gateway element
« Reply #1 on: July 10, 2019, 09:04:01 pm »
Does not look too bad. What version are you using?
Bumble
« Reply #2 on: July 10, 2019, 09:07:49 pm »
Hi, Version 14.1  (build 1427)  Corporate Edition
« Reply #3 on: July 10, 2019, 09:56:31 pm »
Can you tell me where the MDG settings are hidden in V14? This is a real PITA! I know I asked that recently. The forum search (as usual) does not return anything ("V14 MDG" or "14 MDG" -> no results; what??). Also the Search of EA does only show Import/Export and such stuff. But not where to configure the setting. This Is Such A Pain In The Aaaaargggggghhhhhh
« Reply #4 on: July 10, 2019, 09:59:31 pm »
Never mind. Found it. SOMEWHERE at the end of the rainbow.
« Reply #5 on: July 10, 2019, 10:12:53 pm »
The issue is
Just remove that line or replace it with
currentElement.Type = "Decision"
You don't need to alter the types in any case. Just apply the stereotype.
Bumble
« Reply #6 on: July 10, 2019, 10:18:24 pm »
Just tried it and it worked :-)
Thanks qwerty for your help - much appreciated  :) :) :)
