Author Topic: switch all Sparx users to read only mode  (Read 62117 times)
BruceTOGAF2
« on: July 25, 2019, 12:34:38 am »
We are planning to migrate our PRODUCTION Sparx Repository from Oracle to SQL Server. When we used Sparx DBMS to DBMS Project Transfer to migrate our DEVELOPMENT Sparx Repository, it took 4 days. We plan to start on a Thursday evening and complete on Monday. We need to ensure that, during the PRODUCTION migration (4 days), users should not make any changes to the SPARX repository.
Our chief architect wants me to switch all Sparx users to read only mode for those 4 days, so that users can still view (but not update) the Sparx model in the Oracle Repository.
I have experimented with creating a Sparx Security Group that locks the parent package containing all child packages. This experiment did not prevent a user making updates within a child package if the user is a member of the Sparx Security Group that previously locked that child package. I want to avoid the laborious tasks of
•   listing all group-locked packages
•   unlocking all group-locked packages before locking the parent package
•   unlocking the parent package after the migration
•   re-applying all those group-locks after the migration
Please can you advise us on how to switch all Sparx users to read only mode for those 4 days.
Re: switch all Sparx users to read only mode
« Reply #1 on: July 25, 2019, 01:27:17 am »
Why don't you switch the database itself read-only?
Your DBA should be able to help you do that.
PS. 4 days for a database transfer? How big is your database? The models I've worked with transferred to .eap file from 5 minutes to 45 minutes, but never longer.
Funny thing, SQL Server -> .eap file -> SQL Server was faster then SQL Server -> SQL Server.
« Reply #2 on: July 25, 2019, 08:38:46 am »
Well, our experience has been SQL Server -> EAP 7 mins, EAP->SQL Server a couple of hours (EAP file size ~800Mb).  Don't know why.
Your observation of the Funny thing is probably true, but we never tried it.
« Reply #3 on: July 25, 2019, 09:20:37 am »
If I had a similar requirement I would set the model on the cloud server as read-only. Failing that, disable all edit related permissions for all security groups.
BruceTOGAF2
« Reply #4 on: July 25, 2019, 05:39:22 pm »
Hi Geert, No surprise that SQL Server -> eap file -> SQL Server was faster then SQL Server -> SQL Server. Sparx Systems Support told me that eap files are faster than DBMS to DBMS Project Transfer.
However my task is to migrate from Oracle to SQL Server a database that is too large for eap. Sparx Systems Support insist that under these circumstances, I must use DBMS to DBMS Project Transfer.
Since I posted this subject, I have found a simple solution and tested it successfully in DEV. This technique temporarily switches all users to read only mode. In our Sparx Cloud Service Server, I have set the Database Manager to Read-only. In ‘Sparx Cloud DEV Oracle’ I can browse, but I can no longer make any changes.
« Reply #5 on: July 25, 2019, 05:52:53 pm »
However, my task is to migrate from Oracle to SQL Server a database that is too large for eap. Sparx Systems Support insist that under these circumstances, I must use DBMS to DBMS Project Transfer.
Since I posted this subject, I have found a simple solution and tested it successfully in DEV. This technique temporarily switches all users to read-only mode. In our Sparx Cloud Service Server, I have set the Database Manager to Read-only. In ‘Sparx Cloud DEV Oracle’ I can browse, but I can no longer make any changes.
Hi Bruce,
are you using the old Access97 (Jet 3.5) for your .EAP file?  You should switch to the Jet 4.0 engine and the Access2000 .Eapx files.  They should be able to accommodate a large repository.  Did you see our test?  Our .eapx files are over 1GB before compressing.
eberline
« Reply #6 on: July 26, 2019, 04:34:55 am »
3-4 days is about how long it recently took to transfer my .eapx to SQL Server over WAN, w/o Cloud Services or WAN Optimizer or anything like that. The .eapx was about 1/2 GB.
Interesting... I took Sparx at their word in their 2014 whitepaper and elsewhere asserting that for Jet formats, "less than 30-40 mb is recommended".
« Reply #7 on: July 26, 2019, 05:27:43 am »
Wow. What kind of WAN is that? Think of using pigeons with USB sticks attached. They have a much greater bandwidth!
eberline
« Reply #8 on: July 26, 2019, 08:00:35 am »
San Francisco  <-->  Montreal, Quebec; current ping is 66 ms.
(IPoAC? God-like MTU, but reportedly up to 55% packet loss and terrible latency.)
« Reply #9 on: July 26, 2019, 08:02:37 am »
In the OLD days, when we had those stand-alone tape drives and mainframes, it use to be said that the transfer rate of a tape in a lift beat the network transfer hands down...
But that was 4 decades ago...
« Reply #10 on: July 26, 2019, 09:18:30 am »
I was just waving signs. Sometimes you have to dig at different locations to find the bug.
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
« Reply #11 on: September 07, 2019, 08:07:29 am »
I don't know if too late for this idea: what about exporting the users and group permission information (reference data) in XML. Then removing all permissions for groups and users. After migration just reload your reference data and that's it.
« Reply #12 on: September 07, 2019, 09:32:54 am »
Have I missed something? It's possible to export user locks per reference data?
« Reply #13 on: September 07, 2019, 09:50:19 am »
Not the locks but the permissions. If you save the permissions of groups and users, then remove all permissions for all groups, they will have the editing disabled. Then, you can re-import the reference data to get the permissions to the original state.
User locks don't change in this strategy
BruceTOGAF2
« Reply #14 on: September 18, 2019, 11:59:12 pm »
Thank you all for your ideas.  As previously posted .... I have found a simple solution and tested it successfully in DEV. This technique temporarily switches all users to read only mode. In our Sparx Cloud Service Server, I have set the Database Manager to Read-only. In ‘Sparx Cloud DEV Oracle’ I can browse, but I can no longer make any changes.
