Author Topic: Encoding EA GUID  (Read 6362 times)
Modesto Vega
Encoding EA GUID
« on: July 25, 2019, 02:03:55 am »
Is there a way to encode, using a custom code or query, the GUID generated in more user friendly format with less characters?
Re: Encoding EA GUID
« Reply #1 on: July 25, 2019, 02:47:49 am »
I wouldn't do that. A GUID has a defined form. See https://en.wikipedia.org/wiki/Universally_unique_identifier or RFC 4122.
Modesto Vega
« Reply #2 on: July 25, 2019, 02:52:34 am »
AFIK GUIDs including those conforming to RFC 4122 can be encoded using different bases without any data loss, hence the question.
« Reply #3 on: July 25, 2019, 03:45:44 am »
Read the Format section in the Wiki and see if you can get happy with that.
« Reply #4 on: July 25, 2019, 09:29:11 am »
If you're using another tool do what you want. If you're using EA I wouldn't recommend it.
« Reply #5 on: July 25, 2019, 03:16:59 pm »
Depends on what you need to do with it.
If you just want to reference them in a document without using the full guid that would be feasible.
You could for example use only a part of the guid, like the last 5 characters.
There will of course be a higher risk of collisions, but it will probably still be pretty small.
With a simple query
where t_object.ea_guid like '#WC#myGUIDPart'
You could find the elements you need.
« Reply #6 on: July 25, 2019, 05:17:03 pm »
If you're after something like bit.ly for guids you could use scripting with a custom table.
Modesto Vega
« Reply #7 on: July 25, 2019, 08:21:53 pm »
Thanks Geert and qwerty, we are trying to reference them in documents without having to use the full GUID, we are not intending to use encoded GUIDs for import. We would look into using the last 5 characters or do something like bit.ly.
I'll try to post an update when we reach a conclusion.
