Author Topic: Poputlate diagram with elements from SQL  (Read 6209 times)
« on: July 25, 2019, 02:24:15 pm »
Is it possible to populate a diagram using a SQL query to acquire the elements
Re: Poputlate diagram with elements from SQL
« Reply #1 on: July 25, 2019, 02:38:09 pm »
It is for a Kanban diagram. Which is just a diagram showing the elements in columns.
« Reply #2 on: July 25, 2019, 03:03:01 pm »
Pretty easy to do with a script, but you can also do it manually.
Use the SQL query in a search, and then drag the elements from the search results to the diagram.
« Reply #3 on: July 26, 2019, 06:22:38 am »
Thankyou both.
I need to add to my requirements, I simply want the diagram, when opened, to run the SQL script to populate the diagram.
« Reply #4 on: July 26, 2019, 08:09:14 am »
Thankyou both.
We run our auto-populate scripts (MS Access macros) outside EA via our Helper process.  In our case, the population doesn't need to be live so we can schedule the updates externally.
« Reply #5 on: July 27, 2019, 04:13:26 am »
