Author Topic: Difference between a meta-and stereotyped relationship in profiles  (Read 5701 times)
I'm struggling to understand the difference between a  Meta-Relationship connector between two Stereotypes (used to specify a valid UML Connector between these two Stereotypes) and a  Stereotyped Relationship connector between two Stereotypes (used to specify a valid stereotyped connector between these two Stereotypes).
Does the meta-relationship trump (in the contract bridge or whist sense) the stereotype relationship (if I don't specify the meta-relationship, I can't specify a stereotyped relationship whose base type is the meta-relationship type)?
If my MDG has NO relationships defined without a stereotype, do I need a meta-relationship arc at all?
TIA,
Re: Difference between a meta-and stereotyped relationship in profiles
« Reply #1 on: July 30, 2019, 05:24:00 pm »
Use a metarelationship only if you want to define rules for unstereotyped connectors between your stereotyped elements. A common example of this is my stereotype should only have a generalizations to elements with that stereotype.
I think specifying a stereotyped relationship will override any meta relationships that have been defined, including ones defined by us in the uml metamodel.
« Reply #2 on: July 30, 2019, 06:43:11 pm »
Thanks, Eve,
