Author Topic: v15 – Can’t remove bad files from MTS file list  (Read 8139 times)
« on: July 31, 2019, 11:07:13 am »
When generating MDG files, the wizard starts with being able to optionally select an existing MTS file.  The drop-down list cannot be edited (such as to remove incorrectly typed or no longer required MTS file.
Please rectify.
Reported,
Re: v15 – Can’t remove bad files from MTS file list
« Reply #1 on: July 31, 2019, 11:21:19 am »
If you feel comfortable editing the registry, the key name is "MTS Recent File List"
« Reply #2 on: July 31, 2019, 11:26:03 am »
Thanks Neil, I'd worked that out...  But for those not comfortable...
It's bad UIX, ...  ;)
Glassboy
« Reply #3 on: July 31, 2019, 01:41:28 pm »
Are you saying shift+delete doesn't work on that particular control?
« Reply #4 on: July 31, 2019, 03:32:10 pm »
Yes! It only seems to delete the value selected, NOT the value in the list.
Did you try it?  Maybe I'm not doing it correctly...
Glassboy
« Reply #5 on: August 01, 2019, 09:00:00 am »
I couldn't be bothered mucking up the list to try it, but I asked because most people don't know that's the normal key combination for that sort of control.
« Reply #6 on: August 01, 2019, 09:05:18 am »
Yes, it clears the control but not the history.
Glassboy
« Reply #7 on: August 01, 2019, 09:08:19 am »
That's the cause of a lot of organisational data leakage with applications like email clients :-)
