Author Topic: v15 – MTS file list NOT sticky. Used to be?  (Read 4289 times)
« on: July 31, 2019, 11:12:42 am »
When repeatedly developing MDG files, it is very annoying having to repeat the same start to the wizard.  The selection (such as Opening an existing file - and the file selected) should be sticky!  IIRC they used to be (a few versions ago now).
While I'm at it, the opening screen should have a checkbox suppressing it once it is understood.  [ ] Do not show this again.
Reported,
Re: v15 – MTS file list NOT sticky. Used to be?
« Reply #1 on: July 31, 2019, 07:23:18 pm »
That (and the fact that the MTS does not cross check the exports for being the expected profiles) made me write a script to put the profiles together. A very simple mechanism. I had a rant elsewhere that this whole MTS mechanism is flawed. There should be a <<MDG>> object you link to the profile packages/diagrams etc. and then you just context-start the generation from there. Since you can (if I got that right) script the export in V15 I'll start doing so.
