Author Topic: Custom fields in the requirement properties window  (Read 7007 times)
jmcdonnell
« on: July 27, 2012, 12:08:22 am »
Hi all,
Is it possible to add custom fields to requirements properties?
Specifically I'm after something like "Raised by" and "Reason".
If it's not, can anybody think of a good workaround?
Thank you in advance,
Joe
SomersetGraham
Re: Custom fields in the requirement properties wi
« Reply #1 on: July 27, 2012, 12:14:27 am »
You could use tagged values
Using V12
jmcdonnell
« Reply #2 on: July 27, 2012, 12:18:50 am »
Thanks for the reply!  I'd already thought of it but I'm really looking for something more specific so that users wouldn't need to add the fields themselves every time they want to start a new project...
Joe
« Reply #3 on: July 27, 2012, 12:26:25 am »
Create a MDG and define requirements that have the tags you need.
jmcdonnell
« Reply #4 on: July 27, 2012, 12:28:59 am »
I'd like to give that a try!  Where should I start looking if I want to create an MDG?
Joe
Makulik
« Reply #5 on: July 27, 2012, 12:49:14 am »
Start here:
http://www.sparxsystems.com/enterprise_architect_user_guide/9.3/standard_uml_models/creatingmdgtechnologies.html
For your case, simply setting up an appropriate profile for your requirement stereotypes with the additional tagged values (custom fields) should be sufficient:
http://www.sparxsystems.com/enterprise_architect_user_guide/9.3/standard_uml_models/createprofile.htm
