Author Topic: Change artifact to external wiht double click to open  (Read 3158 times)
Pegasus
« on: August 06, 2019, 11:19:58 pm »
case 1: If I drag and drop an external document in to EA and select Artifact (external) a double click on artifact element results in opening the document (like Hyperlink)
case 2: Creating artifact from inside EA e.g. toolbox I get artifact element too. Assigning e.g web adress or local file adress to file. Now I expect same behaviour as in case1 but double-click leads opening property dialog only. Under File I can select the entry and click "Launch" to open file. But this workflow isn't I want to.
What's wrong in my workflow or what to configure to get behaviour described under case 1?
Thanks in advance
Pegasus
